hi
I need to find a TV bracket, needs to swivel at least 45degrees each way, doesnt need to tilt really. TV size won’t be big, twenty something incher.
Main concern is that it keeps TV as close to the wall as possible when not swivelled, as it’ll be in the middle of a room on a pillar, and seen from the side all the time.
Looked at loads online, and seen things like this: https://www.currys.co.uk/gbuk/tv-an...4251-tilt-swivel-tv-bracket-10171250-pdt.html
Which apparently allows it to be about 62mm from the wall, not sure if that can be improved on with a different bracket.
Only ever fitted one of these before and it was a flush/fixed one, so any advice much appreciated. Thanks.
