Hi, I need to know if there are any problems using a TV (Blaupunkt) in the UK that was purchased and used in Switzerland. I know the voltage is the same, but any other problems? Many thanks, GW
The colour system is the same as the UK ie PAL. You may find the sound sub carrier is slightyly different so no or muffled sound if you use the aerial. Scart lead would be fine.
