Tv extension
17 Nov 2005
Manchester
Hello,
I have just fixed a 19inch LCD to my wall and I had a single extension cable which was once for some spotlights on my old wardrobes. The cable is only thin about the same size as you would find on a plug in light will this be ok to power just the TV or should I use thicker cable?
Define 'extension'. Is it a cable fed from an existing circuit (lighting?) or an extension lead?
There's no way any advice could be given with the description you've given.
Can you not install a new socket fed from the ring final in your bedroom?
Its like a 4 way extension only one way
It has a plug on one and end and a socket on the other there is about 6 foot of cable.
Thanks.
Is it a made up extension or a pre made extension? Is the cable 3 core (does it have an earth cable)?
If you have doubts about it then either buy another or have a suitably located socket outlet installed (preference).
Yep its made up (not by me) its 3 core with earth and everything is in good condition.
The only thing that I am concerned about is the thickness of the cable,its only the same as a lamp etc.
Sorry forgot to add, the only thing that will be plugged into this extension willbe the tv.
