I wasn't sure if to post it here or in A/V .... but here goes...
2 year old house, Bedroom internal Stud wall, with insulation. Currently has ring main and Ariel sockets.
I have installed a TV bracket high up the wall, and now need to run some power to the bracket area, ideally internal of the stud wall. The Ariel and LAN feeds are coming from the loft.
Does anyone see any reason or problem with using a standard two gang extension for this? I was thinking using two blanking plates horizontal to each other for entry / exit points. plug on one end and double gang tie wrapped to the bracket at the other.
Would the cable be OK in the cavity wall, pulled in place through the wall insulation?
I know ideally fused spur would be best method, but I already have a fused spur form the socket to the loft power, hence looking for alternate solution.
