I've rented a house with gas central heating and I'm trying to figure out how best to heat only one room. I've thought about getting an electric portable heater, but I gather gas central heating works out cheaper. However, it's a three floor fairly thin house, with the kitchen on the floor, bedroom and bathroom on the middle and the lounge on the top. The thermostat is in the kitchen. Could anyone help me with the answers to these questions
1) Do I have to have the radiator in the lounge set to max? I could lower it but the wiki says the thermostat goes by the room it's in, so cranking it down to 1 or lower would just mean the gas central heating stayed on regardless. I really don't need the kitchen heating, plus the heat generated by the radiator presumably gets spread throughout the upstairs landings as there's no door on the kitchen.
2) Is there any harm in turning radiators off, rather than having them stuck at one? I've heard say that you need to have some water flowing through them and turning them to 0 stops this happening.
3)Does turning a radiator down actually use less gas? So if I have the lounge one at 5, then crank it down to 2, will it be using less gas to heat it?
Advice would be appreciated. I can't actually fit any extra bits and bats as I'm renting.
