Hi all just signed up today so here is first post. I'm from uk originaly but live in Romania now with two small kids and it gets cold. I installed a LPG combie boiler and works fine but is expensive to run soooooooooooooo what i want to do is this. In Romania they have wood burners that are firebricks on the inside and a sort of fancy ceramic fire brick on the out side,when the fire goes out they stay hot for some 12hrs but this is in only one room,so i got to thinking. I built a snake shaped coil from thick steel tube and i have placed this on the inside of the fire in the first smoke chamber (5 chambers in all )
Ok if you are still awake what i want to do is connect this system to my LPG boiler and run it so when/if the wood burner goes out the LPG boiler will kick in and when the wood burner is hot the LPG boiler will close down.
I know i will need to put a pump on the wood burner and a means to get rid of heat if the Electric fails now can i use a expansion bottle/vessel and a pressure release valve on pipe vented to the outside or do i need to have a system the same as in the picture in this link ??? i would love just to have the expansion vessel as it gets so cold here and in loft god only knows.
Many thanks for your time and if you can put me in the right direction i thank you
http://www.boilerstoves.co.uk/boiler-stove-installation-A.html
Forgot i dont want to have the water tank if poss
