two fused spurs from socket junction box
14 Feb 2011
Hello
Can I take two fused spurs from the same radial socket junction box?
Assuming this is a properly protected Radial circuit, and that the terminals in the joint box are adeqate for additional cable(s): Yes, you can.
Lucia.
Hi. Thanks for reply. The radial is protected with 20A fuse and the junction box is a 30A box. Is this OK?
2.5mm2 cable to junction box presently. I'll run 2.5mm2 to both fcu's.
