I’m curious to know whether it is possible or efficient for that matter to use two electric only immersion heater tanks? I vision having one tank on top of another in the airing cupboard, the outlet from the top tank is connected to a pump which will add some pressure to the 6 hot taps within the building, the outlet from the bottom is fed into the top tank. Both tanks would still be fed from the cold water tank within the loft.
I want to achieve double hot water capacity in double quick to heat up.
If this is viable, would there be a technical name I could ask my plumber so we're on the same wavelength.
