Hi experts,
I have an odd problem with my shower tiling. I had my bathrooms tiled four months ago. A couple of inches of grout started to discolour so I removed it but to my surprise it came out easily, like putty.
The grout immediately above and below is rock solid, it's literally only two inches of soft grout. There is no obvious leak but I know it's very difficult to figure that out.
I replaced the grout with premixed stuff (assuming the original grout might not have been mixed properly) and reapplied. Two days to set and it's still soft.
What could be preventing the grout from setting and why is it just two inches? I stuck some blue tissue in the hole after removing the grout and after an hour it was still clean and dry so if there's a damp problem it's not bad.
Some details:
- this wall is the only one which is tile on tile, and the wall itself is concrete
- the two inches are where the glass mosaic abuts regular ceramic tiles
- due to a difference in thickness, the mosaics are fixed to plywood using tile adhesive and the whole lot attached to the old tiles beneath
- the original installer is not coming to help, he just comes out with excuses then doesn't show up.
Any ideas?
Thanks folks!
Some details:
Any ideas?
Thanks folks!
