Two lights with end of run switch
31 Aug 2003
I'm adding a few receptacles and a couple exterior lights in my garage and I'm not sure how to wire the two lights with an end of run switch.
Power to the lights will come from the last receptacle I added, next will be the two lights, and finally the switch I'd like to use to control the two light fixtures.
Is it easy enough to explain how to wire that circuit so I can operate those two lights from that last switch? Also, I'd really like to not only control those two lights from that switch, but if possible I'd like to control that last receptacle from that switch too (christmas lighting).
Any help would be greatly appreciated...
Thanks,
Tom
as this is an english based website, what i would say to work and be in compliance with all regualtions over here, may not be acceptable in America. So i have found an American based forum for you which is here
I only found it after i had typed a long and lengthy reply, which i have now removed
