Back in spring I applied to have the house extended significantly and its roof raised from 4.8m to 6.3m. That application was approved.
In autumn I applied for the detached garage to be extended significantly and a pitched roof to be built over it at a height of 4.5m. That application was also approved.
Now I am trying to amend the application for the garage by increasing the roof pitch and the height from 4.5m to 5.0m.
I have written a supporting letter asking the planner(s) to view this amendment in conjunction with the approved application for the house extension. In that way the roof of the garage at 5.0m is well below the roof of the house at 6.3m. But if the planners look at the existing house, its roof is only 4.8m and I am trying to get the garage to be at 5.0m!
What do you guys think, do I have a point? This is a multi-development, and the pieces blend together - maybe I should have applied for both gasrage and house in one common application? Even if I had, I know full well, they cannot force you to build everything, for example you can build the garage and never build the house (my neighbour case in point, he has built a gigantic tripple garage with 6.0m roof, but has not built the house that was on the same application).
What do you guys think?
