Two shaver sockets in same bathroom
18 Oct 2006
Buckinghamshire
A question for the learned members - just been reading something and it raised a question about having two "shaver" sockets in the same bathroom. Of course the question would be "why do it".
Example - You can now get heated mirror lights many of which include shaver sockets (we had one and never used the socket on it) and you could already have a separate shaver socket.
Does this comply with the regs or is it considered too risky as someone might happen to push a bit of wire into both sockets at the same time?
Is the alternative to disconnect one of the sockets?
Interested to know why you think pushing a bit of wire into both sockets at the same time is more hazardous than just doing it to one.
Only shaver sockets with isolating transformers are allowed but don't do it anyway.
My assumption was that you can hold one side to earth potential for the first socket but does the same apply to the second? Yes, you would have to be stupid to do it but I have seen some stupid things.
The sockets are individually isolated with their own transformers.
The only way to get a shock is to simultaneously contact both poles of one of the sockets. There is no potential difference / voltage between different sockets.
Each on it`s own transformer is the safety part of it in essence, meaning you can not get a shock from earth and one conductor because there is no difference of electrical potential between them.
The only place you would find a difference in voltage is between two power conductors on the same output side of the transformer.
So the only risky part is the part we intend to use electricity from - the two pins.
You could have a hundred bathroom shaver sockets in a bathroom and still have no (almost none) potential problems.
If you could guarantee absolutely in your household supply that neither of your two (single phase) was electrically connected to earthy/meta bits then there would be fewer problems.
Unfortunately you can not absolutely guarantee that will be acceptable because some parts could accidently/unknowingly be connected to earth so we deliberately connect one to earth, we then calls it Neutral and then consider all other Lines to be mains voltage different to both the N & E.
So a bathroom shaver socket has two Lines of opposing voltages and have no opposing voltage to anything else - unless someone then decides to make a deliberate connection to earth from one of them (I can`t imagine that anyone has ever actually done that but there are people who do some very daft things )
Yes it does. The secondary side of each socket is entirely isolated from earth.
