Hi all
On the current job I've to install two thermo mixer showers. Cold is no problem but I'm a bit stumped re hot supply from cylinder. I can fit a surrey flange and then tee in 22 to each shower reducing to 15 at the valve. There will only be about 0.2 bar pressure. Will this work or has anyone a better solution, (more than likely I suspect).
Martin
Martin
