They're now labelled and stored! What are the symptoms of a drill whose brushes need to be replaced? Does it stop altogether or start to make a noise or what? Thanks.
excessive sparking is the first symptom, don't ignore this, as you will stand a good chance of burning the communtator surface, the brushes should be good for about two years normal use.They're now labelled and stored! What are the symptoms of a drill whose brushes need to be replaced? Does it stop altogether or start to make a noise or what? Thanks.
In a very dusty atmosphere this is possible, the fan on the drill draws in air and blows it through the motor.If you actually manage to wear out the original motor brushes I’d be surprised. If you manage to wear out the original motor brushes & the rest of your drill still works OK, it must be a good one & I’d be very, very surprised!
I’ve no doubt it’s possible but I’ve had quiet a few drills over the years & all have had a pretty hard life but I've never had to replace any brushes. I’ve had a couple of drill motors die on me; an old style 2 speed (gears) Bosch where the motor got so hot it melted the casing before it gave up (obviously no cut out) & a variable speed Screwfix which died after just 15 months. I go through cordless drills (on my 5th in 10 years) but not because they wear out, the batteries die after a couple of years & it’s cheaper to buy a new drill than a pair of replacement batteries, if you can still find them.In a very dusty atmosphere this is possible, the fan on the drill draws in air and blows it through the motor. Wotan
It seems that you only get these extra bushes with cheapo Chinese drills. I've never got any with any of the drills from the main makers
