A neighbour has proposed building a full width extension two/three storey's high with a room in the extended roof.
My local planners say we can object through design consideration and how the sheer mass overshadows us.
In their guidelines an example is quoted whereby if a line is drawn from the centre of your nearest window to the uppermost part of their extension and if that line cuts through their building the extension should be refused.
In our case this is marginal.
The example assumed that your windows are in line with the main wall, whereas in our case and another affected resident our nearest windows are bay windows. Can we count our side windows as a separate window as these account for over 20% of our overall glazed area. Also the top panes that are frosted glass are under the lip of the bay above that is nearly 300mm deep.
Many thanks
Many thanks
