I have recently purchased a new PC and I would like to 'manifold' it up to my current machine with a single Flat screen monitor.
I do have a KVM cable and I've used it in the past without problems, but the old monitor had a serial connection (no USB), whereas the LCD flat screen has a single USB port plus a Serial port. Both are required to be connected to the tower for the monitor to function.
The problem.
I have tried connecting the pair up but I could only control one computer with the KVM switch. The tower that had the USB cable connected to it worked fine, but the other was incapable of receiving any commands via the KVM switch, because it was without the necessary USB cable.
The request.
How can I get the two towers to work off one Flat screen monitor. Can it be configured or do I need a special USB adapter or other piece of equipment.
I hope I've made the point clear enough to understand.
Thanks for all help
The problem.
The request.
Thanks for all help
