OK, Thanks, The power cable comes from a plug that is plugged into a power socket. I've tested this and it is live.
I have not disconnected the light fitting so I do not know which wires go where in the light fitting, but it is a simple light fitting with an integral infra-red sensor, there are 4 wires coming from it, red, Yellow, blue and green.
There are 3 terminals on each of the two gangs on the switch. and the live connects, with a link, to one of the terminals on each gang of the switch, leaving two remaining termials on each gang of the switch. I assume that the neutral connects to the blue wire from the light fitting and the Green wire from the light fitting connects to the earth on the switch , but where do the red and yellow wires go? I've tried various combinations, but can't work it out.
I have some very clear pictures and have sent them to DIYNot.com asking them to upload them. I look forward to hearing back from you. Many Thanks Mike147
