- Joined
- 8 May 2007
- Messages
- 231
- Reaction score
- 19
- Country
Hi all I am looking for a solution to a little issue I have. I have never been able to get good DTV reception so have always used sky in the main room of the house and then used the RF out with magic eye in all other rooms and also DTV (all be it intermittent/naff signal)
Now as the main TV aerial from outside went to the sky box and then back up via RF2 it caused naff signal but did allow us to use sky in each room via magic eye so worked fine. Now the kids want to be able to watch something different in other rooms so I need to fix the bad signal issue. If I remove the sky box then we have no problems DTV is good signal and no break in picture.
Put sky box back in and the issue start.
I have a Labgear 12 Way Diglink Amplifier in the loft if I put the aerial direct to that DTV works perfect in all rooms, but If I want the RF2 and the aerial I have to use a splitter as only one IN on the Labgear so I need one that is passive to allow the magic eye to work (the ones I have tried dont work).
I could sketch up my setup if required.
Any ideas?
Any ideas?
