I thought I understood this, but I am not sure I do, now...
I have a shed with a door at each end, and I want to fit two way switches by each door so I can switch the light on and off from either door.
Because of the layout of the shed, I have the power supply near to one switch, and the light is near the other. So the idea is to power the circuit from one end, and connect the lights at the other.
I have three core and earth running between the switches.
Do I...?
At power supply end:
1. Live supply to common
2. Neutral to Grey on 3-core using choc block
3. L1 = Black on 3 core (brown sleeved)
4. L2 = Brown on 3 core (brown sleeved)
At light end:
1. common to light (brown sleeved)
2. Grey to light using choc block
It looks OK to me on paper, but the use of choc blocks worries me - is there a way of doing it without them?
Any advice would be most welcome... Thanks.
Do I...?
At light end:
