We have a two-zone forced water system with a gas furnace. Both thermostats operate their respective valves, but only one actually triggers the furnace. So if the top floor thermostat triggers the furnace, hot water will flow to the lower floor system if its thermostat signals the need, but if the top floor thermostat doesn't turn the system on, the lower floor won't get any heat.
I've changed the thermostat and the Synchron motor valve. This hasn't helped.
