I live in a town house and have 4 (four) Twyford WC's with bottom entry pipe fittings. They're about 8 years old now and within the last two weeks two of them have started leaking. It's a small leak but enough to soak the floor over a period of time (standing on a wet carpet was the give away). The leak comes from around the water inlet pipe but space is so restricted it is very difficult to see exactly.
Now the leak only happens when the water pressure is on. If the cistern is full and no water pressure is applied then there is no leak. It is only when the isolating valve is turned on (even by a small amount), that it starts leaking.
Has anybody experienced this before and have any ideas that could easily fix it?
Like I mentioned, access is very tight and it looks like I'll have to remove both toilets completely to change anything - which seems like a big job for what appears a small problem.
