Had someone come in to level and whack a 100mm type 1 sub base for a patio. I’m some areas I saw them trying to wack 100mm in one go. Will this be weak as not whacked in layers? How can I check the integrity of it? I can kick it up using light force. Surely it should be solid I’d done properly ?
Also there are areas of larger type 1 loose on the surface?
Should I rake this back to 50mm and wack again?
It comes up easy no effort with a rake. Surely should be solid??
