Can a halogen/incandescent GU10 bulb be used in a LED GU10 lampholder?
Also in the following link http://www.megamanuk.com/lightwaverf/helpdesk/knowledgebase.php?article=12 it says that a resistive load might need to be added because the LightwaveRF cannot pick up low loads. Does the inclusion of such a resistive load of 10w, therefore consume an additional 10w of wasted energy, which if I was to have many circuits around the house needing this 10w load, is unnecessarily wasting my energy and increasing my costs?
The section in question is:
Resistive Load: If you have used LEDs other than the ones recommended above (or the above LEDs with Slave/2 Way Dimmer switches) which flicker when on and/or glow when switched off then this is an indication that there is not enough load in the circuit. Halogen and incandescent lighting give a resistive load equal to their stated wattage while LEDs do not. Having 20W of LED lighting does not necessarily give 20W of resistive load. As a minimum resistive load is required for LightwaveRF Dimmers to operate, erratic behavior can result when this resistance is not met.
A quick way to check if an LED problem you have is resistance related is to temporarily replace one of the LED lamps with a 50W halogen/incandescent lamp. If any problems are resolved then the fix required will be to wire a resistive load in parallel across the circuit. LightwaveRF recommend the Danlers 10W “RESLOADE”. In some cases two may be required.
