Type of Chimney pot
3 Feb 2016
Hi I intend to fit a 5kW Small Multi Fuel Wood Log Burner with 2 x1m Straight Vitreous Enamelled Multifuel Flue Pipes straight into the flue. The flue is a Class 1 which has been cleaned and was smoke tested will be sealed with a steel plate.
My question can I use a Slotted Terracotter Chimney Pot
You can, but you'd be better taking the liner to the top of the pot, and adding an anti downdraft cowl as well.
