I have looked all over the forums but cannot find a definitive answer to this.
I employed a poor plumber who has replaced the stopcock in a first floor flat with a too small 'ball' type lever valve - similar to an appliance valve.
It is not 'full bore' (15mm pipe) and so flow is not great with 2 taps turned on.
I wanted to replace it - but with what?
The property has a stopcock in the street that shuts off ground floor and first floor flats together.
This small lever valve under the sink is the only means of shutoff to the first floor flat.
My main question is - should it be replaced with a traditional t-handle type stopcock - and would that prevent backflow under negative pressure conditions or can it be a larger bore lever valve (and would that also need a non return valve added as well)?
My concern is that when I had the water to both properties turned off (for other work) I could hear water from my pipes in the first floor draining down to the flat below when they opened their taps!
Is there something inherent in the design of a normal stopcock to prevent backflow - the arrangement of the washer perhaps?
Sorry I know from reading the forums that this question crops up regularly but I can't find the definitive answer I'm looking for.
Thanks!
Thanks!
