Hi all,
In order to get a wall flattened out quickly today, I bought from B&Q a tub of U-Can repair mortar. http://www.diy.com/departments/u-can-brick-wall-repair-mortar-5kg-tub/242770_BQ.prd
It says you just add 300ml of water to 2.5Kg of mortar, apply and 2 hours later it will be set.
Well after 6 hours it was still soft and a bit flakey. The room has just been plastered yesterday so the air is probably fairly moist. I have stuck a heater in the room overnight.
Any ideas if it is likely to be slow due to the moisture, or will I be scrapping it off again tomorrow morning and buying something better from the builders merchant?
Tim
Tim
