We have just bought an old farmhouse in NE Scotland. We are planning to lift the original pitch pine floorboards and install a wet underfloor heating system, then re-lay the floorboards.
We have received lots of conflicting advice regarding this, and the latest is that we shouldn't install same, as all wooden floorboards have a moisture content, which will dry as the heating is on - causing the boards to contract. Then as the heating is off, the boards will expand again. Appratently if this is the case, this will cause movement which will in turn cause plastered walls to crack.
How likely is this? The floor boards are in excellent condition (having been protected by a series of wildly patterened nylon carpets over the years) and they are straight and thick, with little or no gaps. Moreover, the wood has been there possibly since the house was built, in 1895 - surely they would have seasoned by now?
What do you think? Is this a potential disaster? And if so, what do you recommend we do?
Thanks for any help.
BB
BB
