The problem is running the waste from a bath in a Grade II listed cottage.
Can the U trap consist of a vertical descent to between the joists, then about 1.5 metres horizontal under the floor to the wall then a vertical ascent to be above the floor thus forming a U trap. At that point can be run along the wall to the far corner where it can descend again to run under the floor to the external hopper.
The Part H regs do not seem to give a maximum for the length of the U bend's horizontal section.
Rodding acess would be provided at the wall end.
The retention of the hopper which drains to a ground level gulley is a requirement of the conservation officer as is retention of the cast iron stack pipe that serves only the WC ( not 490 years old ) so cutting into the stack is not an option.
The bath's location is determined by the load bearing capacity of the 490 year old joists which seemed to be about to drop the previous bath into the dining room below.
