I am looking to insulate my 1969 build ground floor flat.
External / Party walls & ceilings I have a handle on what I'm doing.
When it comes to the flooring, I am wondering how much leeway my local LBA might give me in new flooring thermal elements.
I am looking at installing Spacetherm C on the floor to minimise loss of headroom (I'm loosing 70mm with doing the ceiling). I'm assuming a solid 125mm concrete base, vapour layer & 50mm screed on top (which seems to fit with what I found when I dug out some blown screed a while back)
My question is to do with P/A ratio. If I use the total floor area, and exposed perimeter I can get a U value of 0.25 (to BR spec) with 10mm Spacetherm bonded to 19mm chipboard. However, if I do the calcs on a room by room basis two of the rooms which have a larger exposed perimeter would need 20mm spacetherm (which starts to get very expensive).
Which is the correct approach ? Room by room, or can I argue whole slab ? Obviously I'm hoping that I can go towards the latter. If the former, a couple of the rooms have a calculated U value of 0.3. Would the LBA give me that much lattitude ?
Also, when looking at exposed perimeters, Do I need to include walls boundarying unheated spaces (e.g corridor between flats) in the P value ?
So far as I can tell, the internal dividing walls are all built directly on the concrete slab. The only exception being the central dividing wall, which is load bearing.
Any guidance would be appreciated
Matt
Matt
