I am planning to install a wet underfloor heating in the ground floor (suspended timber) of my 1930 house.
I will be running a windproof membrane over and between the joists to hold some insulation. I am currently leaning towards wood fibre panels as the joists are uneven/wraped and fitting cellotex will be likely leave a bunch of gaps.
To support the pipes, there seems to be two main options compatible with my plans:
aluminium spreader plates
or joist panels
made of 70mm polystyrene. I could fill the rest of the cavity (~30mm) with fibrous insulation.
Does anyone have any insight on the best technology between these two?
Polystyrene is about 0.036 W/mK, which is nearly identical to wood fibre, and inferior to PIR (0.022 W.mK).
Spreader plates have more aluminium and should result in better conduction/more even floor temperature.
Some UFH suppliers warned me against spreader plates as they may sag under the weight of the pipes and loose contact with the floorboards.
or joist panels
