Which pipe, PEX AL PEX, Pert al pert, Pex al HDPE all the different suppliers offering different pipes, choices of manifolds and controls. Trying to decipher the best option or supplier for my install. Does anyone have any knowledge, experience or recommendations? I will later extend ufh further into other area (another story) but will probably site another manifold for that rather than try to fit a larger than needed manifold. I'll have to run a fair length of flow and return pipe to it too which will go in the screed.
It's 30m2 single room with vaulted ceiling, new build single storey extension. Slab is down, will be fixing to 100mm celotex type insulation then screeded over. Possibly flow screed or traditional, not sure yet what I will use, depth available will determine. Between 70-60mm depth I think but will need to lazer all over to get better idea. I guess I can vary the celotex thickness 10-20mm and still comply with regulations but prefer more insulation than less!
