M
marsaday
i am installing UFH in the kitchen. the house floors are concrete on the ground floor. i have taken up the layer of modern ceramic tile, a layer of screed, the old clay tiles, another layer of screed and am now into the brick and sand base the builders originally put down in 1910.
i need to take up about 7cm of this base, but am concerned this is quite important for the foundations of the building. i have done a trial hole and this base covering is 15cm approx thick. Should i be concerned?
2nd question is should i lay down a thin screed over this rubble (say 20mm) on which to sit the insulation then the 65mm screed. or will a blinding of sand be adequate. i will be using a membrane as well.
