Recently installed Underfloor heating. in a renovated Timber clad building with suspended floors.
The walls are all filled with 100mm insulation in between and 50mm over studs.
Floors are 50mm celotex overboarded, with aluminium spreader plates and 18mm t+g flooring on top. 15mm engineered oak finish floor.
Boiler is a Worcester Bosch 27i system condensing boiler.
6 zones (on an 8 zone manifold) largest being 100m, smallest zone 50m. Digital programmable room stats for each zone. Actuators all working.
All air purged from system at start up. Flow rates attempted to be adjusted (cannot quite get the 2 large zones showing as fully open, they currently sit at 4 on flow meters)
Only one Zone reaches 18 degrees, all other zones, even the small ones struggle to reach temps of 15+ degrees
Any help would be super appreciated!
Kris
Kris
