I am about to order wet underfloor heating for our screeded floor area. As far as I can see there are two ways of laying pipes in screed - either using "plates" where the pipe sits on a plastic mat and wraps around preformed moulding or using staples which just push into insulation at regular spaces.
I like the system plates as it does make the job easier and its not much more (around £50 altogether) but to me it looks like it will reduce the amount of contact between the pipes and the screed. Because the pipe is wedged in bits of plastic, the surface area that can be covered in screed is reduced which to me would reduce the efficiency of the system.
With staples on the other hand, pipe is completely exposed and the screed would wrap them completely so it sounds like a better job when done.
The company I am buying this from are telling me its other way round - with staples you have more chance of air pockets and reduced efficiency and plates are better. They couldn't explain why though.
Any thoughts on this?
