Am thinking of getting a David Robbens single room kit (up to 14m sq) to heat the 2 new rooms I have had built - a utility room and a study.
The study is 2.2m x 2.9m,
The utility is 2.2 x 2.13 m and will have a u-shaped unit layout around it.
The floor will be celotex with screed. There is a block wall dividing the two rooms.
Questions:
1) Will it be possible to use the single room kit to serve both rooms. I understand that they would have to be on the same "zone" and would not be able to be adjusted independently.
2) Should I lay pipes underneath the "cupboarded" area, or should I just put them under the open floor area?
Any thoughts or advice welcommed.
Cheers
Paul
Questions:
Cheers
Paul
