I have hard wood floor board (tongue-grooved) fixed to joists, which are secured into I-shape steel beam on one end and into a wall on the other.
The floor board is parallel to the beam and extends over I-shape beam from joist. In theory, the I-shape steel beam and the joists should be level on the top edge. however, floor over joists have 5mm lower than floor over I-shape beam so my flood is not even in the nearby of the steel beam. I would like to know what I can do to bring the floor over the beam to the same level as those over the joist . Many thanks for any help you may offer.
