I took 3 rad's off upstairs during decorating.
shut valves both sides of the rads, All have thermo controlled valves, so took caps off and tightened the centre piece down to close off.
We used the central heating with those rads off.
I've put all 3 back on again, and put the thermo valves back to exactly same position.
Only one of the rads (a double rad) will fill up, the other two do nothing, I've tried closing all the rads off and working on each of the two that won't fill, they gurgle and start filling for a couple of mins then stop, nothing happens, no air from the bleed valves at all, tried pumping water round with just one of the troublesome rads and it gurgles as though small amounts of water is going in, but I get no air coming from the bleed, any Ideas? should I just persevere as I'm doing now with pump pushing water round until it eventually drives the air out, or has anyone any better suggestions
