Morning all,
Got a problem with a heating system.
A mate drained his system and only managed to get about a bucket of water from the system. Now that's he tried to refill it there is a whole load of air in the system and most of the radiators are only half full and no matter how much bleeding he does they just don't fill.
He called to see if I could give him a hand. I went into the loft and could only find one header tank. Now is it likely that this header tank supplies both the water cylinder AND the heating system? Surely not - that could make for some pretty filthy hot water!
I suspect that he has a blockage on the cold feed (either that or the vanishing header tank supply has been isolated but I can't switch the valve back on because I can't find the damn tank!).
For the time being, I was thinking of sticking a hose onto one of the draincocks downstairs and filling it the same way as it's supposed to drain. Do I need my mate upstairs bleeding air out of an air valve as I'm doing this?
Thanks in advance for your help.
