Unable to open door
19 Nov 2011
Essex
This morning I closed my back door and when I ttried to reopen by pushing down on the handle it wouldn't open. Eventually I did get it to open and have sprayed it with WD40. The handle still doesn't fully retracted the latch (if that is the correct name, not sure) into the door. As a temporary measure I have placed duck tape over the latch and using a brick to keep it closed in the day time to keep the heat in.
I have a separate mortice lock to lock the door but I need to be able to open and close the door. I have had a look online and I'm comfused by the variety and different sizes available. What do I measure to get the correct size? I know the make of the latch is Yale but no idea of any other information
Also do I need to replace the handles at the same time. How can I find which one to buy and is the removal and fitting of a new one within the capabilities of a person with no DIY skills.
Thanks.
Wooden door?
Can you remove the latch mechanism?
Really need picture.
Upvc doors you will need to get trade in to fix.
If wood
Maybe remove screws holding both handles from inside and out.
Remove handles.
Remove screws holding latch from the side.
Might need to push bar back in then grasp either side of bar and pull latch out.
Now size it up and buy replacement.
It's a wooden door. I haven't tired to remove anything yet. Thought I would ask before I did anything.
You will need to get latch out and just use the lock for now..
See what replacements are about for it.
