I have a leaking mixer tap which I think I can dismantle once I get the tap tops removed. However, I can't get the tap tops off and need some advice
The mixer tap is probably about 20 years old with a central swivel mixer pipe, with hot tap on the left, cold tap on the right.
Each of the taps has a removable top cover which when removed reveals a single central screw. I can remove the screw from either/both taps, but am then not able to remove the tap cover.
If the tap cover can be removed, then I can get at the tap body, but I am reluctant to apply too much force to the tap cover for fear of causing damage.
Is the tap cover just a push fit onto splines ?
Any suggestions on how to remove much appreciated
Thanks for any help
Thanks for any help
