- Joined
- 13 Sep 2015
- Messages
- 114
- Reaction score
- 6
- Country
I've just fitted a Hansgrohe Raindance Select thermostatic mixer shower. With both hot and cold supplies running to it it gives water that is only "quite warm" (which is not warm enough for SWMBO to shower in it!) If I turn off the cold supply, it gives fully hot water.
Hot is supplied by an unvented cylinder (heated by a system boiler). This is the first item tee'd off from the incoming cold main. Feed pressure to the cylinder is reduced to 3.5bar.
Cold is supplied from the mains. When I last measured this it was around 4.5bar.
There is a lot of pipework between those pressure measurements and the shower. The hot also takes a bit more of a windy path through the house. My suspicion (unchecked) is that the pressure differential at the shower will be greater than the one bar measured at source.
I assume this pressure differential accounts for the lukewarm water issue. I'll check in the morning by turning a few other cold taps on, see if I can get the shower to right itself.
So, what to do? With practical local limitations in mind, options I can come up with are:
(1) Fit a PRV to the cold at source, immediately after the feed to the hot unvented cylinder, bring the cold feed to the whole house down to 3.5 bar, matched as best I can to the hot. Easy to do, but problem is it doesn't guarantee there still won't be a pressure differential at the shower given very different pipe runs.
(2) The PRC to the unvented cylinder actually has a balanced cold supply (unused). This would be a real faff to do, but have the whole house cold come off this. Same problem as (1), but I guess you can at least guarantee the thing is 100% balanced at source.
(3) Using that balanced feed just to feed the shower is not an option - would involve ripping up building fabric to plumb a new hot supply.
(4) Fit a PRV on the cold supply on the branch to the shower (so, only the shower cold feed is regulated down).
(5) Fit a pressure equalising valve on the hot and cold feeds to the shower.
I think I am favouring (5) - thoughts?
As always, many thanks for your help (and apologies for long post - trying to be thorough).
JC
JC
