Afternoon all,
I've been planning and preparing my kitchen and dining room and thought I'd finished sorting out the electrical stuff. I've added a new ring main for general sockets (RCD protected) and also added a new ring for the oven (13 amp), hood, fridge and freezer which will be on the unprotected side of my new CU.
I've realised though - I've forgotten to make provision for under cabinet lighting - DOH!
Now I realise that the easiest way would just be to have plug in lights under the cabinets but as I haven't yet plastered the room it makes sense to have provision for the lights to be hard wired with concealed wiring.
One problem I have is that I won't be having one long run of wall cabinets so link lights are out. I have one wall where there is a 400mm cabinet, extractor hood & another 400mm wall unit. On the wall opposite there will be two 600mm wall unites joined together.
Ideally I'd like to have all lights controlled by one switch.
My main question is, where to I situate the connections in preparation for the wall units going up after plastering?
Can I simply take a spur from one of the rings to a switched FCU and then run from the FCU to three or four flush mounted mounting boxes one by one, effectively creating a mini radial from the ring, fused where it leaves the ring?
Can the mounting boxes be situated in the area behind the wall unit so there's no cover plate visible (I haven't got the units yet so don't know if there's any void behind the back panel)?
What are the best lights to use for this? I was thinking of strip lights. Any recommendations?
Cheers all in advance
Fred
P.S. This is all part of an overall project which BC have been advised of and will inspected before being covered up. I don't think I need to notify them of the additional work because the original notification specified the installation of two new rings in the kitchen so if I can simply spur off one of the rings then it means I don't have to re-notify of further work (i.e the extension of a lighting circuit).
Fred
