Hi
I'm in the process of getting a fitted kitchen and wife has now decided that she wants that under counter lighting. Fair enough.
Now, the issue i have is i am trying to plan the electrics and there will be FOUR strips of these lights, one under counter on left, one under counter on right (5m apart) and on the front bottom of the island and the back bottom of the island.
I have seen that each strip (there will be four) has its own starter and this has an on-off switch, what wife would like would be one wall mounted switch which would control all of these four parts.
The only way that i can see this work would be to tee off the lighting circuit and connect each of the four starters together and then back to a switch and then turn them all to ON and should work
Is this the right way to do this?
