Under counter water heater
21 Oct 2014
Nottinghamshire
I'm wanting to install a new 3kW under the counter water heater. I was going to use the existing supply to the old water heater which is on the ring-main. The consumer unit has no RCD.
My question is, do new water heaters need to be protected by an RCD?
Thanks.
You should plan for a new circuit not plan to put a 3kW water heater on a ring final.
