Hi, A couple of questions about UFH if i may.
I have been told that retrofit UFH and above ground level installations are rather impracticable and costly, so i make the assume that it is possible to have some radiators and some UFH on a mixed system with a single boiler.
If this assumption is correct, then how does the boiler control the water temperature to the different heating ordnance. I understand that the water in the UFH is rather cooler that that in the rads.
Secondly, I am told that the timing of heat in areas with UFH is different from standard rads. I can't easily see how this could be controlled either.
Anybody with the lowdown on such things out there - much appreciated. I am building an extension and want to use UFH in the new bit but rads in the old bit, but i want ot make sure it is a reasonable suggestion before i go much further.
Thanks,
Thanks,
