I am gathering information prior to building a swimming pool and wanted to know if anyone has any views with regard to insulating under the floor of the pool.
The walls will be constructed using Quad-Lock which will give an R-value of up to 40 which is great but I will still loose heat through the floor.
Two questions:
1) If I use Dow Board (Styrofoam, FloorMate) will I suffer a cracking of the surface or edges due to compression if I screed over it ?
2) The pool is effectively a tank so could I construct the tank on a bed of styrofoam which is tied down to a foundation slab using rebar hooks?
The pool will be about 1.80 deep so the walls will stand about 2 meters from the foundation.
If anyone has any thought or suggestions I would be very happy to know them.
Matthew
Two questions:
Matthew
