Ok this is i presume a pressure problem, just wanted to get some opinions please. valliant combi boiler doesn't fire up hot water for the kitchen taps (closest to boiler if that makes a difference) BUT is fine for the bath tap and if you run the bath hot water tap at the same time as the one in the kitchen then hot water also comes out in the kitchen
Could it be that the pressure is too high from the mains? so the kitchen tap on its own doesn't lower it enough to get the boiler to fire up? the bathroom tap has a large outlet. Can i sort this out by tweaking the water mains valve tap? or could it be more sinister
No problems with central heating. Sorry i don't have more details on the boiler at the moment if needed i can get these. Also could i really mess things up if i go 'tweaking' the mains tap?
