Can I get some advice please.
10 litre under sink heater.
I have had an under sink water heater for the last year or so and all has been fine, then one day the pressure relief valve kicked in and started releasing the water. I thought it might be the valve that was broken so I replaced it, but this did not sort the problem.
In looking around it seems there should be a expansions vessel in the pipe work which there is not. So I am looking at fitting one of these and hope this will sort the problem.
But I have a concern, which is at the moment the prv is always loosing water not just when it heats up and the water expands.
So I can't under stand why I'm loosing cold water when the prv is 6bar and the mains is 4bar
I hope that make sense and the spelling in readable
Thanks for any help
Thanks for any help
