We had underfloor heating fitted upstairs and downstairs late last year. It’s working fine as far as I can tell. However I’m not sure of best practice for UFH.
The installer told us that underfloor heating should be left on all day long at a low temperature and it would be fine because UFH only “sips” power to heat up.
We have no gas so we had a new oil boiler fitted at the same time as the UFH. However, as oil boilers generally don’t modulate like a gas boiler, surely the boiler is either on or off and whether it’s heating one room or five rooms, it’s burning the same amount of oil. Is my understanding wrong? It feels like oil is possibly a bad match for UFH?
Maybe wrongly but I’ve set the system up to switch on and off throughout the day (at different temperatures depending on the room) allowing warm up time.
I worry that it’s burning up a lot of oil. The set back temperature is set to between 16 and 18 degrees so certain rooms that fall below that are forcing the boiler to fire up during the night and again burn fuel. I can of course adjust the setback temperature to a lower temp but that might be defeating the object.
I hope this makes sense to someone.
