- Joined
- 26 Jan 2005
- Messages
- 266
- Reaction score
- 0
- Country
I'm looking at installing some electric underfloor heating under my bathroom floor tiles (yet to be laid)
The installation of the heating side looks OK, I just have a couple of queries re the electics side.
The instructions seem to say it can be run off either its own fuse spur in the fusebox, or can be wired into an existing ring main.
If I used an existing one which circuit should it be taken from - I assume upstairs sockets?
I'd prefer to run a new dedicated spur from the fusebox. There is a spare one, but the RCD fuse box is down in the kitchen, with the existing wires going up through some trunking within the kitchen wall. This has been plastered in now, so I'd rather not take it out and disturb the plaster in order to feed a new wire through. Are there any tools avaialble specifically for pushing a new wire up through existing trunking, or is it asking for trouble to mess with existing cabling behind a wall? I'm sort of thinking that if I can push a thin piece of plastic pipe up through the trunking with the existing wires I could then push a new cable up through the pipe?
Fianlly, are there any regs as regards the location of the heating element and wiring in the bathroom apart from the usual bathroom stuff of nothing over the bath?
Hope this makes sense - I'm sure I must have got some of the terminology wrong.
